Craig Chase
Gear Guru
Hi all - We recently ordered a pair of Axiom LFR-1100 Active speakers for both ownership and review. The passive LFR-1100's are one of my all time favorite speakers, and consist of 3 front firing, 6.5 inch long throw woofers, 2 front firing 5.25 inch mids and 2 front firing 1 inch dome tweeters. They also have rear firing dual 5.25 inch mids and dual rear firing 1 inch dome tweeters.
The passive units also use a DSP which gives a VERY flat response curve from about 30 Hz and up, including what is known as the Sound Power Curve. This curve was pioneered by Floyd E. Toole, and is a measurement taken in intervals on a total of 360 degrees in both the horizontal and vertical plane. Toole has discovered through 1000's of hours of blind tests that the better a speaker does with this curve, the more the speaker sounds like a live performer.
The active versions of this speaker take performance even higher by having all crossovers done at the pre-amp level and each woofer, midrange and tweeter array getting its own dedicated 325 WPC (8 ohm) amplifier. This means TEN amp channels to drive the two speakers.
The speakers are in production now, with a lot more information to follow.
