avr630 or RX-V2400 or 914k w/ carver av505?
Discussion in 'AV Receivers' started by TyreeS, Apr 16, 2004.
  1. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    plz i want to decide on this soon. my old sony is giving out on me
  2. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    i guess u can add the STR-DA4ES and the AVR-2803
  3. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    1,357
    The 630 doesn't need the Carver to sound good, and to a lesser extent, neither does the Yamaha. If either of the 3 receivers you listed could benefit better from the Carver, I would say the Pioneer would.
  4. Kevin Alexander
    Apr 17, 1999
    1,357
    I can't speak for the Denon, but I have a DA4ES, and there is no way I would hook up a Carver 505 to it. The amps in the DA4ES are better.
  5. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    thx keep them commoing. and i was more looking at just hooking up wht carver w/ the 914k only.
  6. Laurence_C
    Laurence_C Stunt Coordinator
    Sep 30, 2001
    173
    North Florida Panhandle
    Laurence
    I don't own any of the above receivers or amp, but the soundstage with the Carver will definitely be expanded with any of those receivers, but not greatly. The Carver is a pure amp and I'd suspect it would out-perform any of those receivers amp sections. I say this since I own its big brother the AV-705x. I know those receivers are rated to have a boat load of power but I bet the Carver's amps have better specs across the board and not the inflated specs that receivers tend to have in the perfect laboratory setting that the manufacturer has performed. I bet the receivers listed would clip before the Carver.
