Bob-E
- Sep 21, 2002
I just purchased the following HK Components:
AVR520
PA2000
DVD50
FL8380
I’m not sure I understand the purpose 6-Channel and 8-Channel Direct Inputs. I’m using the PA2000 to power my FL and FR towers and then connected the SBR and SBL preamp outputs to the FL and FR Amplifier Inputs. I connected the DVD audio using an optical cable and the CD player using a digital coax. Do I not have this set up right? When or why would I use the 6-Channel or 8-Channel Direct Inputs?
Thanks!
AVR520
PA2000
DVD50
FL8380
Thanks!
