AVR240 or TXSR503 or VSX-515
Discussion in 'AV Receivers' started by Jennifer Sfo, Mar 29, 2006.
  1. Jennifer Sfo
    Jennifer Sfo Auditioning
    Mar 27, 2006
    I got the polk rm6800 speakers. I am yet to buy the receiver.
    Can you suggest one among
    AVR240,
    TXSR503,
    VSX-515 or VSX-815
    That is the order of its pricing too.
    What do you suggest for subwoofer cable, speaker wire and plugs keeping the cost in mind. Please be specific. I am not sure if it comes with the receiver or if I will be able to use them.
    Thanks in advance.
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Any of them should work with those speakers, but of those choices, I'd definitely go with the H/K AVR240.
    What's your budget? The receiver will come with no cables besides power and antena.
    For things like sub cable I like www.bluejeanscable.com , but there are less expensive (and likely lower quality respectively in most cases) than that however if that is not the price you are looking for. Value vs quality is very high with Bluejeans. www.partsexpress.com has quality wire, banana plugs, and things like digital and analog interconnects in a wide range of prices.
