AVR 8000 what type/size input jack for 12 volt trigger
Discussion in 'Archived Threads 2001-2004' started by Curtis Lotter, Feb 13, 2003.
  1. Curtis Lotter
    Curtis Lotter Stunt Coordinator
    Jun 21, 1999
    75
    Hi
    The kind Fedex driver just dropped off a AVR 8000 at my place [​IMG]
    I'll be using a Parasound 2205 amp which I previously had hooked up to my Yamaha DSP-A1. The Yamaha didn't have a 12 volt trigger so I used a 12 volt wall wart to turn on the amp. (I now want to use that same wall wart to power a cooling fan)
    The Parasound can be hooked up on its' end with a couple of stripped leads, what size or type goes into the AVR 8000? It looks like a 1/8" mini jack but I don't know. Don't have any prior experience...
    Thanks!!!
  2. Scott Pagac
    Scott Pagac Stunt Coordinator
    Jul 9, 2001
    114
    1/8" minijack is correct. However, I believe it is supposed to be a mono connector.
  3. Curtis Lotter
    Jun 21, 1999
    75
    Thanks for the reply Scott.
    You were right about it being mono, I did finally find more on the remote trigger by going on HK's website and downloading an amplifier pdf.
    It specified using a 3.5 mm mono mini plug.
    The next paragraph explained how to use a DC adapter if your receiver wasn't equipped with a trigger, quite informative!
    Thanks again.
    Curt
