AVR-4802R DENON- what do you think
Discussion in 'AV Receivers' started by jason123, Oct 28, 2003.
  1. jason123
    jason123 Agent
    Aug 8, 2002
    37
    I am thinking of getting the AVR-4802R DENON. I currently have a Yamahaw DSP prologic 1 (5yrs old)
    What do you guys reccomend that I change in my setup.
    FYI-I do not have tons of $$$
    Prewired for 5.1, My room is 15x15
    12", 250-Watt Down Firing Powered Subwoofer
    JBL Northridge E Series Dual 5" Center-Channel Speaker
    JBL Northridge Series 4" 2-Way Bookshelf Speakers (rear)
    Cerwin Vega 12" 3-Way Floor Model (Front)
    E-712 Description: 12" 3-Way Floor Model
    Frequency Response: 28 Hz - 20 kHz
    Power Handling: 300 watts
    Sensitivity: 98 dB (2.83V/1m)
    Impedance: 8 ohm compatible
    Protection: Self-resetting PTC (tweeter); Fuse (system)
    Video Shielding: No
    Dimensions: 33" x 14 3/4" x 13 3/4"
    (H x W x D) 83.4 x 37.5 x 34.9 (cm)12"
  2. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    IMHO the 3803 offers all the features that you'd need, and if you want more power add a Parasound 1205a 5ch amp. [​IMG]
  3. jason123
    jason123 Agent
    Aug 8, 2002
    37
    What is the main difference between the AVR-3803 and 4802R... Is it the THX? Please help if I can save $1000 I will go that route.
  4. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    I would get a 3803 and use the $1000 to get a separate amp (even if used) under 1K. For HT this will give you a better sound compared to the 4802 by it self, IMHO. Plus the amp can stay in your system for ever while you keep upgrading the prepro so in the long run this will save you even more. The 3803 by itself is a very competent receiver so you dont even have to get the separate amp right away. Just enjoy the 3803 for now and when you feel like rocking the HT even more you can always get the separate amp.
    Best of luck.
  5. jason123
    jason123 Agent
    Aug 8, 2002
    37
    Sorry what is a IMHO
  6. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    IMHO is "In My Humble Opinion"... and IMHO splitting your $$ up towards speakers AND a receiver would be a better use and yield a more noticable increase in sound quality. A 4802R would greatly outclass your speakers and using your budget for speakers and a receiver would give you much more bang for the buck.
    Assumming you're starting out w/ $1500 (4802R cost online), I would put $1k towards speakers and $500 towards a receiver. There are some great deals to be ahd on the JBL studio series and since you seem to like JBL and BIG front speakers you may want to consider a pair of S310 mains, S26 surrounds, and an S Cetner (around $900 online after shipping).
    There are alot of other brands of speakers that you can put together a great 5.1 system for $1k, especially the internet direct companies like Ascend, Axiom, and my favorite Swans from www.theaudioinsider.com . A Swans system consisting of 4.1 tower mains, 2.1 surrounds, and a C3 center would run a little over at $1130 but would be a huge step up even from the JBL Studio series IMO. The cabinetry w/ the black cherry and piano black w/ the top-mount tweeter similar to B&W is just gorgeous and the sound quality is amazing as well. The 4.1/2.1/C3 system is what I personaly have and from my listening I don't think I could have done better for the money with any other brand... I don't think I could have done better for twice the money shopping at bricks and morter stores either.
    If you keep the sub you already have for awhlie you can make the rest of your budget go farther for the receiver. In the $500 to $600 range look at the Denon 2803 and 3802, or maybe even a 3803 if you can catch a deal on a used or refurb on ebay or audiogon. If you don't mind straying away from Denon, give the Pioneer Elite 43TX and 45TX a look, as well as the Harman Kardon 525 and newer 430.
    I think putting your money into speakers AND a receiver will make the budget go farther and give a much larger increase in sound quality. Driving the speakers you have now w/ a 4802 would not do justice to the receiver and would only leave you wishing you had great speakers to take advantage of it's potential, and no money to buy great speakers with.
    Hope this helps
