AVR 320 setup help
Discussion in 'Archived Threads 2001-2004' started by mike_doyle, Dec 5, 2002.
  1. mike_doyle
    mike_doyle Agent
    Nov 22, 2002
    34
    OK, here are my speakers, All Paradigm:
    Speaker..............Response ...........LFE (DIN)......Efficiency
    ADP 170 Rear____90Hz – 20KHz_____65 Hz_________90 dB
    CC 350Center___70Hz – 20KHz____57 Hz__________93 dB
    Monitor 3 front___58Hz – 20KHz____38 Hz__________91 dB
    I was thinking of setting all speakers to large and setting the X-over to 60 Hz. then I started wondering if i should set the center and surrounds to small and the X-over to 80 Hz?
    Any opinions suggestions?
    My room is about 10 by 15 ft.
  2. Rick_FL
    Rick_FL Stunt Coordinator
    Dec 4, 2002
    171
    I'd set them all to large, and x-over freq to 60hz, and use lfe+l/r. anything 60hz and under will get played by both fronts and the sub. Experiment a little. you may find you like another combination better
  3. mike_doyle
    mike_doyle Agent
    Nov 22, 2002
    34
    I was thinking about the LFE = L/R
    Right now I am running 2 Klipsch 15" subs off of a 100w x 2 amp. So i get tons of Low Bass...
