Avia or VE to set sub output?
Discussion in 'Archived Threads 2001-2004' started by DaleI, Jan 3, 2002.
  1. DaleI
    DaleI Stunt Coordinator
    Jun 5, 2001
    128
    I have my sub set perfectly using the VE white noise at 75 db (70 on the spl); when I put the avia disk in and set my spl to 80, the sub reads much to hot. So I adjust it downward, but then it's to low when I try the VE white noise (at 70 on the spl).
    Which is best for sub settings: Avia or VE?
  2. Jason Wolters
    Jason Wolters Stunt Coordinator
    Dec 18, 2001
    227
    What are your bass management settings?
  3. DaleI
    Jun 5, 2001
    128
    I have a Sony sawm40 sub and have all set to small; I have my amp subout to -13 and am controlling the sub volume by using the sub's volume control--halfway up for a cleaner sound--setting it to 75 db. Just wondering why the discrepancy in avia and VE.
  4. Nick P
    Nick P Second Unit
    Feb 11, 2001
    270
    DaleI,
    You're not alone. The same thing happens to me when I switch between Avia and VE. Not sure if this is why but it's my understanding that the tones on VE are a true LFE signal and the tones on Avia are bass signals in the main channel, not the LFE channel.
  5. Rick Radford
    Rick Radford Supporting Actor
    May 12, 2001
    642
    Check out this thread by Guy Kuo for sub calibration with Avia.
