Avia or DVE???
Discussion in 'Displays' started by GregCole, Mar 4, 2004.
  1. GregCole
    GregCole Extra
    Feb 13, 2004
    24
    I have the S & V disk, but I'm looking for a little more detail. Which disc would you all suggest?
    DVE or Avia?
    Thanks- Greg
  2. MikeEL
    MikeEL Auditioning
    Feb 25, 2004
    4
    Hey, Greg, how you like this rain?
    You may want to try researching over at another site that has as it's mascot a spotted dalmatian dog. They have a whole forum on DVE vs Avia. I think I would go with Avia as there are also numerous guides available if you get stuck or wish for more in-depth discussion.
    I like S&V for the quick and dirty adjustments, tho. JMHO.
  3. GregCole
    GregCole Extra
    Feb 13, 2004
    24
    Thanks Mike, it's a nice day. If you're a duck! What area are you in?
    Greg
  4. DuWayne
    DuWayne Stunt Coordinator
    Sep 8, 2003
    160
    I like the NEW DVE (Sep. 2003) over Avia, way more info/test/templetes. It also has HD support.
  5. MikeEL
    MikeEL Auditioning
    Feb 25, 2004
    4
    I have yet to see the new "D"VE - i didn't know they added THAT much stuff. There was way too much stuff for me even in the old VE version! I wonder if there is a digital Avia on the way? Probably....
    Greg, I work in Springtown and live in Nixa (don't we all?)[​IMG]
  6. MuneebM
    MuneebM Supporting Actor
    Jan 12, 2004
    621
    For picture calibration: Avia
    For 6.1/7.1 speaker calibration: DVE
  7. DuWayne
    Sep 8, 2003
    160
  8. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Does DVE have this many test signals and the large amount of posted usage hints of AVIA on the forums? DVE "HD" on the disc isn't on the DVD. It's a separate video tape.
    TitleChapterAudio Test Signal
    62Channel Identification (5.1)
    6565 Channel Speaker Balance
    63Left-Front Level
    64Center Level
    65Right-Front Level
    66Right-Surround Level
    67Left-Surround Level
    643Phase Left-Front/Right-Front
    644Phase Left-Front/Center
    645Phase L-Surround/R-Surround
    646Phase L-Front/L-Surround
    69Subwoofer Level, Left-Front
    610Subwoofer Level, Center
    611Subwoofer Level, Right-Front
    612Subwoofer Level, Right-Surround
    613Subwoofer Level, Left-Surround
    614Subwoofer Phase Filtered Pink Noise, Left-Front
    615Subwoofer Phase Filtered Pink Noise, Center
    616Subwoofer Phase Filtered Pink Noise, Right-Front
    617Subwoofer Phase Filtered Pink Noise, Right-Surround
    618Subwoofer Phase Filtered Pink Noise, Left-Surround
    619Subwoofer Phase Warble Sweep, Left-Front
    620Subwoofer Phase Warble Sweep, Center
    621Subwoofer Phase Warble Sweep, Right-Front
    622Subwoofer Phase Warble Sweep, Right-Surround
    623Subwoofer Phase Warble Sweep, Left-Surround
    625Wideband Pink Noise 5 Channel Pan
    626150 Highpass Pink 5 Channel Pan
    627Circulating Ambience Generator Clicks
    655Pink Noise Match of Center Speaker
    647Low Frequency (200 to 20 Hz) Sweep, Left-Front
    648Low Frequency (200 to 20 Hz) Sweep, Center
    649Low Frequency (200 to 20 Hz) Sweep, Right-Front
    650Low Frequency (200 to 20 Hz) Sweep, Right-Surround
    651Low Frequency (200 to 20 Hz) Sweep, Left-Surround
    652Low Frequency (200 to 20 Hz) Sweep, LFE
    628Low Frequency Pink Noise, 5 Channel Pan
    629Low Frequency Pink Noise, 6 Channel Pan
    631Wideband Pink Noise, Left-Front
    632Wideband Pink Noise, Subwoofer Level, Center
    633Wideband Pink Noise, Subwoofer Level, Right-Front
    634Wideband Pink Noise, Subwoofer Level, Right-Surround
    635Wideband Pink Noise, Subwoofer Level, Left-Surround
    636Wideband Asynchronous Pink Noise, 5 Channels
    TitleChapterVideo Test Pattern
    11Needle Pulses
    12Needle Pulses + Steps
    13Black Bars + Log Steps
    14Black Bars
    15Black Bars + Half Gray
    16Black Bars + Half White
    17Vertical 10 IRE Steps
    18Horizontal 10 IRE Steps
    19Crossed Step Scale
    110Vertical Brightness Steps
    111Horizontal Brightness Steps
    112Black
    11310 IRE Window
    11420 IRE Window
    11530 IRE Window
    11640 IRE Window
    11750 IRE Window
    11860 IRE Window
    11970 IRE Window
    12080 IRE Window
    12190 IRE Window
    122100 IRE Window
    12320 IRE Window
    12410 IRE Field
    12520 IRE Field
    12630 IRE Field
    12740 IRE Field
    12850 IRE Field
    12960 IRE Field
    13070 IRE Field
    13180 IRE Field
    13290 IRE Field
    133100 IRE Field
    199Black Bars
    1102Vertical Gray Ramp
    1103Horizontal Gray Ramp
    1104Crossed Horizontal Gray Ramp
    1105Crossed Vertical Gray Ramp
    21Center Cross 30 IRE
    22Center Cross 50 IRE
    23Center Cross 100 IRE
    24Crosshatch 30 IRE
    25Crosshatch 50 IRE
    26Crosshatch 100 IRE
    27Crosshatch Inverse
    28Dot Hatch 30 IRE
    29Dot Hatch 50 IRE
    210Dot Hatch 100 IRE
    211Dot Hatch Inverse
    212Circle Hatch 30 IRE
    213Circle Hatch 50 IRE
    214Circle Hatch 100 IRE
    215Dots 30 IRE
    216Dots 50 IRE
    217Dots 100 IRE
    218Gray Field Dots
    219White Field Dots
    220Black Field Plus
    221Gray Field Plus
    222White Field Plus
    223Checkerboard 30 IRE
    224Checkerboard 50 IRE
    225Checkerboard 100 IRE
    227Crosshatch 1.66 30 IRE
    228Crosshatch 1.66 100 IRE
    228Crosshatch 1.66 50 IRE
    229Crosshatch 1.85 30 IRE
    230Crosshatch 1.85 50 IRE
    231Crosshatch 1.85 100 IRE
    232Crosshatch 2.0 30 IRE
    233Crosshatch 2.0 50 IRE
    234Crosshatch 2.0 100 IRE
    235Crosshatch 2.35 30 IRE
    236Crosshatch 2.35 50 IRE
    237Crosshatch 2.35 100 IRE
    238WSE Crosshatch 30 IRE
    239WSE Crosshatch 50 IRE
    240WSE Crosshatch 100 IRE
    241WSE Crosshatch Inverse
    242WSE Circle Hatch 30 IRE
    243WSE Circle Hatch 50 IRE
    244WSE Circle Hatch 100 IR
    245WSE Dot Hatch Inverse
    246WSE Dot Hatch 30 IRE
    247WSE Dot Hatch 50 IRE
    248WSE Dot Hatch 100 IRE
    249WSE Dots 30 IRE
    250WSE Dots 50 IRE
    251WSE Dots 100 IRE
    252WSE Resolution
    2154Crosshatch 1.78 30 IRE
    2155Crosshatch 1.78 50 IRE
    2156Crosshatch 1.78 100 IRE
    31Resolution 100 TVL
    321Resolution 200 TVL
    322Sweep
    323Sweep 50%
    324Multiburst
    325Multiburst (Labeled)
    326Multiburst 50%
    327Multiburst 50% (Labeled)
    328Sharpness
    41Blue Bars
    42Red Bars
    43Green Bars
    44Split Color Bars
    45Split Bars with Gray
    46Crossed Bars
    47Minimum Phase Bars
    48Maximum Phase Bars
    49Full Bars
    410Split 100/75 Bars
    411Full 100 Bars
    412Split 100 Bars
    413Full 50 Bars
    414Split 50 Bars
    415Yellow Field
    416Cyan Field
    417Green Field
    418Red Field
    419Magenta Field
    420Blue Field
    51Color Decoder Check
    52Y/C Delay
    53Zone Plate
    54Zone Plate (30 frames/sec)
    55Gamma Chart
    5616 Rectangle
    57Overscan
    58Backlight Levels
  9. GregCole
    GregCole Extra
    Feb 13, 2004
    24
    Wow, information overload. Thanks for the input.
    MikeEL, maybe we could get together sometime for calibration trials. My wife and I are going to Columbia for the MU/KU game this weekend. Maybe next weekend? I'll supply good food! Let me know.
    Thanks- Greg
  10. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    You should see him do that list for Avia Pro.
    [​IMG]
  11. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,343
    Adam
    From a simple usability perspective I prefer AVIA. The original Video Essentials was by far the hardest disc to navigate I've ever seen. The newer DVE is easier to get around in, but is still a little labyrinthine. AVIA is also, IMHO, far better for subwoofer calibration.
    Adam
  12. GregCole
    GregCole Extra
    Feb 13, 2004
    24
    I've decided that for the $, I'm going to pick up DVE and then get the Avia II when it comes out. Thanks for all the input.
    Greg
