Avia Help Part Deaux
Discussion in 'Speakers & Subwoofers' started by JoeyR, Sep 14, 2006.
  1. JoeyR
    JoeyR Second Unit
    Jan 1, 2003
    422
    Joey
    Ok I got my Avia disk and SPL meter today.
    I ran auto MCACC on my 1014 to get the distance, I then went to manual MCACC and set the channel lever for each one as per manual(75dB)
    I than ran the AVIA disk and ended having to turn the db up on all my speakers, some as much as +5.0 and that bothered me, so I went back to the manual MCACC.
    I set my dial at -20 before starting, I then went and set each speaker where I was reading 80db at my seat, one thing I noticed was I had to set my SVS
    at +3.0 db to read 80db. Is this going to burn up my beloved SVS?? Did I do this right? I'm more of a picture and a manual type of guy, I like to see what I'm doing and be able to reread over it. I didnt even try anything with my subwoofer gain/phasing..................
    Any advice is appreciated.
  2. JoeyR
    JoeyR Second Unit
    Jan 1, 2003
    422
    Joey
    Wow..........................................
    a home theater forum and no one can help me.
  3. Jacob C
    Jacob C Second Unit
    Mar 19, 2005
    257
    I think you will be fine. I run my sub 'hot' on my reciever and lower on the sub amps so my sub come on when I am listening at low volumes. Calibrate it and listen to some music and some movies and see how it sounds.
