Nate Nelson
- Mar 12, 2002
Well, I finally got around to buying the AVIA DVD along with a rat-shack meter to calibrate my system. I did the best I could based on my limited knowlege and the instructions on the DVD. I watched a couple DVD's and definitly noticed a difference in the fact that the speakers were much better balanced and it made a big difference in the overall soundstage. Worth the invenstment of the $40 DVD and the $40 rat-shack meter? Definitly.
However I got kinda lost when I ran through some of the bass phasing tones and all. I played around with the phase knob on the amp of my SVS and I couldn't hear a difference (goes from 0-180 degrees). It said the rat-shack meter wasn't necessary duing this test so I dont' know what I'm supposed to hear for or if I do use the meter, what I'm supposed to look for. What is this really for and is it all that important?
Also when you play the tone that goes from the mains to your sub so you can set the correct volume level on the sub, is the needle on the rat-shack meter supposed to jump around a quite a bit (quite a bit being +/- 4db?) And yes I had the rat-shack meter setup right (C weighting-slow response)
One last question, how do I know where to set the crossover? I can set it to 100/150/200 on my reciever or I can use the amp on my sub which goes from 50-150Hz. I currently have x-over bypass "on" on my sub and my reciever is set to 150Hz. Does the x-over for each HT differ? And if it does, which test on the AVIA disk should I use to properly set this up.
Sorry for these noob questions :b I do appreciate those that have made it this far in the post though
My system is as follows if it's even important:
Klipsch Quintets for mains/surrounds
Klipsch SC-1 center
SVS 25-31pci
Pioneer D509s reciever
JVC XV-300BK DVD-Player
27" GE T.V.
etc, etc. I know it ain't the best but its all this poor 17 y/o can afford at this time
Klipsch SC-1 center
SVS 25-31pci
27" GE T.V.
