Larry Chanin
- Jul 24, 2001
Hi All:
In trying to figure out what's going on with my processor filtering the test signal, I just recalled reading the following instructions prior to taking room measurements in Lucasfilm's Home THX Audio System Room Equalization Manual:
Switch your Home THX Controller to the “Dolby Pro Logic Surround” mode. The Home THX Cinema mode must be switched off for this procedure. Note: For Controllers featuring Dolby AC-3 Decoders, there is no easy method to insert broad band pink noise into this signal path. Equalization should be done through the Dolby Pro Logic mode on these controllers as well.Although I performed the measurements with my main speaker set to large and the subwoofer off, I was using my default surround setting on my Lexicon processor, which was Logic 7. Tonight I'll try another measurement with Dolby Pro Logic and see what happens.
Larry
