Average CPU temp??
Discussion in 'Computers' started by Ian_H, Apr 2, 2004.
  1. Ian_H
    Ian_H Supporting Actor
    Aug 6, 2001
    569
    Anyone know what the average CPU temp should be for a Athlon XP 3000+ w/ 333mhz FSB? I built a new rig last week and I am having stability problems. According to my mobo's health status it is usually around 55c to 62c. I am running it with the stock heatsink and fan that came wiht the chip and i have an Antec P-160 case. I was a little bit worried about the airflow so I have the case side completly off and am getting thos temp readings.
    Thanks!!
    --Ian
  2. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    55c to 62c may be a little warm, but i dont think it is anything that could cause stability problems. maybe your psu is too small. i remember reading that athlons could operate under 95c, but that may not be for a newer one like you have.
    CJ
  3. Ian_H
    Aug 6, 2001
    569
    I have a Antec True Power 550 PSU. I was thinking PSU as I have every molex in use.
    -Ian
  4. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    You should be under 50C with decent cooling. You're not there currently so look to get a better HSF first and then case cooling.
  5. Ian_H
    Aug 6, 2001
    569
    Well I have seemed to fixed my stability problems. I upgraded my chipset drivers and haven't had a crash yet. I always forget about getting the newest chipset drivers.
    -Ian
