AVA250 or AMP350 for Tempest
Discussion in 'Archived Threads 2001-2004' started by JohnA, Jul 16, 2001.
  1. JohnA
    JohnA Stunt Coordinator
    Oct 25, 1999
    98
    I have finalized the specs on my DIY tempest, a 202 litre (net) enclosure tuned to 17HZ, Thanks to alot of personalized help from Dan Wiggins at Adire and this messageboard.
    I had finally settled on the AVA250 to power the sub because of the excellent price/performance ratio.
    I recently recieved a suggestion to use the Stryke AMP350 in place of the Adire unit.
    Any comments or suggestions specific to these two amps is appreciated. I must point out that I am leaning towards the AVA250, if for nothing other than I feel Dan has really earned my business.
    However, I have gone too far not to consider all the options.
    -JohnA
  2. Gregg Hart
    Gregg Hart Stunt Coordinator
    Apr 15, 1999
    167
    I am selling a brand new AMP350 in the For Sale section for $175.
    My Home Theater
    [Edited last by Gregg Hart on July 16, 2001 at 07:06 PM]
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    The AMP350 has a 6db bass boost at 30hz you don't want when you have a large enclosure, low tuning Tempest. They ask you to call to find out about having that boost modified or removed. The AVA250 doesn't have any bass boost which is what you want with your Tempest's design. The AVA250 also has a rumble filter that kicks in below 18hz that will make it more or less impossible for you to bottom your sub. The Stryke site says nothing about a rumble filter on the AMP350.
    In LspCAD a AVA250 has you just barely under the Tempest's Xmax while the AMP350 has you just over it. So the AMP350 will allow you to go slightly louder. I won't get an AMP350 though unless I had the bass boost removed.
    So I would find out how much it will add to the cost to have the boost removed. Then compare the prices and decide if the 1-1.5db gain in output the AMP350 would give you is worth the extra cost and not giving Dan your business after all the help he gave [​IMG]
    Plus with the AVA250 you only have to pay shipping once and it will all come in one package at the same time.
  4. JohnA
    Oct 25, 1999
    98
    Dustin
    Thanks for the excellent response. The guidance Dan has given me is worth more than the 1-1.5dB gain the AMP350 would provide. Even if I decided the 1-1.5dB gain was worth it, I would feel compelled to send Dan a check for his troubles. I strongly recomend Adire Audio to all the other newbie DIYers out there
    Once my enclosure is completed, I will place an order with Dan.
    -JohnA
  5. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  6. Dan_D
    Dan_D Stunt Coordinator
    Jun 18, 2001
    98
    heh my Tempest enclosure is complete and i just ordered my AVA250, tempest, and ports too. cant waittttttt till it all gets here!
  7. Tyler
    Tyler Stunt Coordinator
    May 8, 2001
    112
    I would go with the AVA250 it's a perfect amp for the tempest ( well thats what i hear )
  8. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    John, I have an AVA250 on my Tempest sonosub and it works great. I can't imagine needing more power and I do have a large space to fill. The circuit specified by Adire to the amp manufacturer is, as noted above by others, spot on.
    http://www.geocities.com/hankbond1/My_page.html
  9. JohnA
    Oct 25, 1999
    98
    Thanks for all the replies. They are really appreciated.
    Dan_D, I have been following your posts, as your sub is very similar to what mine will be. I can't wait to see more pictures and hear about the results.
    Hank, great looking sub!
    Thanks again to all,
    -JohnA
  10. Dan_D
    Jun 18, 2001
    98
    thanks man, its turning our pretty good so far. ill have my page updated soon enough
    http://thend.org/~dannydigital/tempesthowto.html
