David_Merrow
- Mar 25, 2001
Hello,
I have decided to build the av1+, but I have a few questions. First, is it worth it to get that blackhole 5 material or would it sound just as good with polyfill? Second, how well does the Sonicap capacitor upgrade work? Lastly, does the internal bracing need to be rounded off on the edges? I ask this because I do not have the router bit needed to do it. And I was thinking about ordering the pre made front baffle. If I do this then I would like to not have to buy any router bits.
thanks,
David
thanks,
David
