AV Receiver offering bi-amp
Discussion in 'AV Receivers' started by Joe Thompson, Sep 29, 2003.
  1. Joe Thompson
    Joe Thompson Stunt Coordinator
    Dec 16, 2002
    128
    Why doesn't any manufacturer offer switching capabilities for bi-amp.....if you have 7 amps & are using only 5 for surround...wouldn't it be great if you could use the other 2 to be able to bi-amp your main speakers for 2-channel listening.....Does anyone think this should be an option or am I just crazy?
    Thanks....
    Joe
  2. Keiwana
    Keiwana Stunt Coordinator
    Jun 20, 2003
    59
    The Pioneer 45tx does givs this option. I am almost sure the new 55tx and 53tx will offer the same feature.
  3. Geno
    Geno Supporting Actor
    Oct 1, 2001
    637
    I think the mentality [of manufacturers] is that if you are picky about your sound enough that you will have totally seperate componants and not even consider owning a receiver.
    For your theory to work, you would have to have a switch that changed the inputs for the remaining amps. currently [i just read the above post, so i am mistaken] in all receivers, each amp [channel] is designated and cannot change. It would be a neat ferature, but I can see how confusing it could get actually engineering it right.
    If you really want to get into bi-amping, your only way right now is to add external amps. I know, sounds silly considering that you dont use 2 amps in your receiver anyway...
    geno
  4. Dave Moritz
    Dave Moritz Producer
    Jul 7, 2001
    5,959
    621
    9,110
    California
    Dave Moritz
    The Denon AVR-5800 has assignable amplifiers but I am not sure if you can assign them in a biampable configuration. I was told at the CES show that the amplifiers in the reciever could be assigned to zone 2 and zone 3 when using external amplification. If anyone owns a Denon 5800 reciever feel free to jump in and let us know if it can be set up in a biamp mode?
  5. Gene DellaSala
    Gene DellaSala Auditioning
    Sep 8, 2003
    8
    Hi people, I often wondered this myself and thus figured out a way to do it at least on Denon gear such as the AVR-5803. I am sure teh 4802/3803 and others will work this way as well.
    Here is an excerpt from my review of the AVR-5803 that you may find helpful.
