I'll put in my vote for the Salamander Synergy. I've got a Twin 30 rack in Cherry with a drawer and a door (http://home.hiwaay.net/~jmoral/HT/).
The only thing you might want to know is that the side panels that slide into the synergy rails have a *slight* bit of play in them (so you can slide the panels in). This can be a problem if you have your subwoofer located near the cabinet as they WILL rattle. My solution was to tuck a piece of business card or index card in between the panel and the rail to snug it up. I called Salamander and they also suggested using a clear caulk to silence the rattles.
My .02 worth.
-Jonathan
"We're hosed. We lost the remote."
I just order the 6 shelf Sanus Euro a few days back, they are modular so later, if need be, you can combine two of them into any size configuration you need. Sanus also has reduced /extended pillars for height flexibility, they also carry a complete line as you can see in the link below, I believe Best Buy is stocking the Euro speakers stands now http://www.sanus.com/cgi-bin/web_store.cgi http://www.audioadvisor.com/store/pr...20Audio%20Rack
Alfonso,
That Sanus Euro style would go well in my room. Let us know how it works out. I'm particularly curious about the weight capacity of each shelf, given it's advertised at 125 lbs on the web site. Hopefully you have a hefty amp or two . Also, did you order any extra pillars? It doesn't seem as if audio advisor stocks them, though.
Thanks.
Doug
"Today is a good day to die." ...Old Lodge Skins
