AV-3 Roundover bit
Discussion in 'Home Theater Projects' started by Nick Hallett, Feb 8, 2004.
  1. Nick Hallett
    Nick Hallett Agent
    Nov 25, 2003
    42
    For Brian or Hank or whomever....
    What size of a roundover bit do you use for the sides of the AV-3 cabinets? also, it seems like it would be a fairly large bit and I don't have a variable speed router. It's a 2.5 HP Makita, so I've got plenty of power. I don't know if I should be spinning a 2" bit at 22,000 RPM though... is this a problem? Thanks.
  2. Paul His
    Paul His Agent
    Jan 10, 2004
    29
    You have a valid concern - that is definitely higher than recommended speed for a bit of that diameter.
    I have not used a separate speed control for a router but they are available - do a google search for "router speed control" and go to first response at mlcswoodworking to see what I mean.
    Paul
  3. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Nick, I didn't round over the newest A/V-3's, but I have rounded over nearly all the cabs I've built. For monitors and towers, I've used a 3/4" radius roundover bit. Is your bit 2" radius? I have a 1 1/4" radius bit, and it is BIG. A 2", cutting deep enough to leave a smooth transition on the baffle and adjacent side, would leave about 1/4" of MDF between the outside middle of the rounded corner and the inside corner of the baffle/adjacent side joint corner. You could brace the inside of that joint with a 1" x 1". BUT, the mid-woofs are about 1" in from the baffle edges. A 2" radius transitioning smoothly into the baffle would begin rounding the baffle about 1 3/4" in from the baffle edges. It will not work. Draw it on graph paper - that's what I just did while writing this response. A 3/4" radius is esthetically pleasing and will allow you to wrap one piece of veneer from one side, across the baffle and around the other side.
    If you're not talking about a 2" radius bit, but a bit that is 2" overall diameter, then ignore my post.
    You should crank down the router speed a bit, and the aftermarket speed controller will be fine.
  4. Nick Hallett
    Nick Hallett Agent
    Nov 25, 2003
    42
    Hank, I meant 2" diameter just as an arbitrary figure for a large bit. I havn't got a roundover bit yet, or the AV3 kit yet for that matter...
    I'm just trying to think what else I need before I start ordering. 3/4" roundover, new spiral upcut, 3 phase powermatic table saw...[​IMG] Thanks
  5. Paul His
    Paul His Agent
    Jan 10, 2004
    29
    Now you're just being silly - you can get away with a single phase powermatic [​IMG]
    Paul
  6. Nick Hallett
    Nick Hallett Agent
    Nov 25, 2003
    42
    Yeah yeah, I'm pretty happy with my cute little folding Ryobi[​IMG]
  7. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    A 3/4" roundover will require a 1/2" collet and a speed control on the router. I was afraid mine would take my hand off until I tried turning the speed down. If you only have a 1/4" collet, a 1/2" roundover should be fine.
    Tables saws should not be cute.
