C
Chris*Liberti
I am planning on buying 2 AV-15's and I am looking for design help on a cabinet. I am planning on using them in either a sealed or a Passive Radiator setup. What is the advantage of each and what size box would I use with each. Also if I go PR what size and weight radiators should I go with. I want bass extension to atleast 20Hz if not 16 or 18 Hz. The lower the better. Also I want the bass as fast as possible without getting too low of output. I plan on using this for 50/50 HT/Music. Also what kind of power should I run to the pair. Thanks for the help
