Auto backup to a secondary internal drive?
Discussion in 'Computers' started by Ken Holmes, Jun 13, 2004.
  1. Ken Holmes
    Ken Holmes Stunt Coordinator
    Jul 11, 2003
    102
    I want to have any file that I change in my "My Documents" folder to be automatically backed up to a folder on a secondary hd. Does anyone know if it is possible to do this in windows xp?
    Ken H
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    I think you'd need to RAID them (raid 1), but that would need a RAID controller card.
  3. Mike_J_Potter
    Mike_J_Potter Second Unit
    Dec 26, 2003
    262
    You could also configure a script to copy the needed files to the second drive at startup or logoff or set it up under scheduled tasks to run at times of your choosing. You can use xcopy to setup the copy script. Here is an example note that the quotes must be in the long file name in order for xcopy to read it. The other parameters will only copy newer files once the initial copy is done so it will run faster. You will just need to make a new file under notepad and save it as a .bat file by changing the file type to all files then type in the full name example backup.bat I think there are other utils out there that do this also but this is a cheap and easy way
    Here is the sample for copying the contents of my documents to d:backup
    xcopy "C:Documents and SettingsmikeMy Documents" d:backup /s /d /y /i
  4. AjayM
    AjayM Screenwriter
    Aug 22, 2000
    1,224
    Run a Windows Backup every night on files that changed and save the file to the new drive.
  5. Brian E
    Brian E Screenwriter
    Aug 12, 2000
    1,636
