Auto 16:9 Enhancement V-Compression?
Discussion in 'Archived Threads 2001-2004' started by Paul Arnette, Jan 27, 2003.
  1. Paul Arnette
    Paul Arnette Cinematographer
    Jul 16, 2002
    2,616
    Hi all.
    While I am woe to add yet another thread about auto 16:9 enhancement, v-compression to this forum, I had a couple of question to which I did not see the answer as I was performing my search.
    I recently purchased the Sony KV-32FS100 for "casual" viewing in our family room. Since my primary set is an HDTV-ready Mitsubishi WS-55905, this is my first set with the 16:9 enhancement feature. The two questions I have are the following:
    1.) Since this is a non-HDTV set, I assume that I am to set the progressive scan player I have, Panasonic RP-62, to interlaced mode for use with the 16:9 enhancement, even though I will be telling the DVD player it is connecting to a 16:9 set, correct?
    2.) Since the 16:9 enhancement is automatic, I assume that if I play a non-anamorphic DVD, I do not need to do anything through the set's menu? The TV will be "smart enough" to make the distinctiion between anamorphic and non-anamorphic, and the 16: 9 enhancement feature on the TV will not adversely impact my watching of a non-anamorphic disc?
    Many thanks in advance.
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Correct. [​IMG]
    Regards
  3. Paul Arnette
    Jul 16, 2002
    2,616
    Thanks for confirming my thoughts on the 16:9 enhancement, v-compression.
    In playing around with my set last night, I do have one further question. Does the Sony KV-32FS100 truly have automatic 16:9 enhancement, v-compression? In looking at the menu, it appears to be an option that one has to manually turn on. Although I admit I have yet to try it with an anamorphic disc, as all of my DVDs are currently packed away at another location.
    Thanks.
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    On some of the Sony sets, the auto detect only works on S-video mode.
    Of course ... no big deal either way unless one is monumentally lazy. [​IMG]
    Regards
  5. JasonRH
    JasonRH Second Unit
    Jan 8, 2001
    496
    Paul,
    16:9 mode should be a manual only process on that set.
  6. Paul Arnette
    Jul 16, 2002
    2,616
  7. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I know for sure the FV(SDTV), the HS(HDTV) and XBR(HDTV) series' do it automatically. My 32HV600 does it on component video as well as s-video and progressive as well as interlaced.
