Authorized internet dealer?
Discussion in 'AV Receivers' started by Kevin_F, Feb 12, 2005.
  1. Kevin_F
    Kevin_F Stunt Coordinator
    Dec 1, 2004
    246
    Is Pricegrabber an authorized Marantz dealer? How can I tell what sites are and are not?
  2. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    Pricegrabber is not. Generally pricegrabber is just a best price finding solution and points you to another site to buy the product. 99.9% of those are unauthorized dealers.
    To my knowledge the only 2 authorized web dealers for Marantz are:
    http://www.hifi.com
    http://www.ac4l.com
    You won't likely get any discounts there and they stay strict to MSRP. The only "breaks" you get would be if you go b-stock or refurbished. AC4l.com sells the refurbs usually.
  3. Kevin_F
    Dec 1, 2004
    246
    Thanks Shane
  4. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
    Check the Marantz site for dealers and also check the internet dealers to see if they advertise as authorized dealers. JR/6th Ave/OneCall/Oade and this forums sponsor are authorized dealers for everything they sell.
    http://www.hometheaterforum.com/htfo...hreadid=219006
  5. Shane Martin
    Sep 26, 1999
    6,017
    One thing I found strange is that the forum sponsor is seling older stuff for Marantz it looked. They all showed a 1 yr warranty where Marantz says it has a 3 yr. Something don't add up there.
    if Oade is selling Marantz, they are awesome to deal with. First rate service.
