Chris_James
- Jan 28, 2003
Ok, here goes my first post
I currently have a home sorta-theater setup going on with a Sharp 27" TV, Apex DVD, VCR, a JVC stereo receiver, and two older Fisher floor speakers (15" woofer, 5" midrange, 3" tweeter). This setup "sounds good" to my newbie ears. I am planning on building a modest system in the $2500 range over the next year or so, and am going to start out with the receiver instead of the TV, due to budget. In the $300-500ish range (street) my list began with the following units (+/- a few I cant think of) Component video ins/outs are a pre-requisite:
Panasonic SA-HE100
JVC RX-8020-VBK
Pioneer VSX-D811S
Yamaha HTR5550
Denon 1603 and 1803
Kenwood 6060 and 6070
Harmon Kardon AVR-325
As I go down the list the receivers (roughly) get farther out of my price range. I have likes and dislikes for all of these units. The main concern on my mind is can I, personally, distinguish the difference in sound quality between a cheaper unit and a more expensive unit? Especially with my current setup? I went out to the B&Ms this weekend (BestBuy, Circuit City, Goodguys, Magnolia) but wasnt really able to audition any. Too that end, my next plan is to purchase a cheaper unit and a "high end" unit, and try them both out. Most likely the Pioneer and the Denon 1803, as they are both available locally. Any tips on this? I guess just pop in some dvds and listen carefully with both units. Will I be sorry if I cant tell the difference now, but when I upgrade speakers find that I went too cheap on the receiver? Any and all advice appreciated. Sorry for the longer post, thanks in advance.
Chris
Panasonic SA-HE100
JVC RX-8020-VBK
Pioneer VSX-D811S
Yamaha HTR5550
Denon 1603 and 1803
Chris
