"Audition" dvd subtitle question
Discussion in 'Archived Threads 2001-2004' started by Sean Patrick, Aug 23, 2002.
  1. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    I have a 16:9 television and a Panasonic RP91 that scalesnon-anamorphic discs...this is the first disc i've tried scaling that has subtitles, and a good bit of them seem cut off.
    1) is there a way to "move" the subtitles up? they seem player generated.
    2) is there any setting on the RP91 to work around this?
    PS - there doesn't seem to be any close captioning for my TV to generate subtitles.
    thanks
  2. Mark_Wilson
    Mark_Wilson Screenwriter
    Jul 27, 2000
    1,800
    You can shift the image up. Is in one of the 'display' menus. Check the manual for which 'icon' it is.
  3. Sean Patrick
    Apr 22, 1999
    732
    but for a non-anamorphic 1.85:1 dvd, i'd be losing a whole lot of image on the top, right?
    i think for now i'm resigned to watching it windowboxed on all 4 sides on my 38" 16:9 via my rp91 - it keeps the OAR, and the image is still bigger than it would be on my 27" tv upstairs which is 4:3.
