Audiosource Amp5.1monoblock amplifier (1 Viewer)
Frank Carter
SOLD
Audiosource Amp5.1 for $65 plus actual s&h.
Also includes original box, detachable power cord, and manual.
Specifications
*Amp 5.1: 70 watts (8 ohms) 100 watts (4 ohms)
*5.5" x 2.75" x 11.75", 9 lbs
*XLR: 20K ohm; RCA: 10K ohm input impedance
*Balanced (XLR) & Unbalanced (RCA) inputs
*Speaker & Line Out/Thru (RCA) outputs
*Damping factor: >200 (4 ohms)
*>95 dB S/N ratio
*20 Hz to 20KHz (±1 dB) frequency response
Frank Carter
Rodney,
As long as you could wire them to a 4 ohm load, there would be no problem. Are they 4 ohms each?
My brother was using it to power a single 4 ohm DIY subwoofer and it had plenty of power hit peaks above 105dB. Bass shaker's shouldn't be a problem.
atlanticshores
