Audiophile Midiman WITH internal sound card?
Discussion in 'Archived Threads 2001-2004' started by Terry Wysocki, Mar 11, 2002.
  1. Terry Wysocki
    Terry Wysocki Stunt Coordinator
    Nov 21, 2001
    69
    I installed an Audiophile 2496 on my new HTPC but I'm not sure what I should be hooking up to what. Should I enable the internal motherboard sound system? How does my DVD player's sound get to my receiver if I don't have a digital audio cable hooked to my soundcard (the 2496 doesn't even have a connection on it for this)? Any clarification here is greatly appreciated.
  2. Seungsoo Hwang
    Seungsoo Hwang Stunt Coordinator
    Aug 6, 1999
    204
    i believe the 24/96 does have coax digital out. You connect this to the digital-in of your receiver.. If I understand you correctly, you defintely do not want to use your motherboard's sound since you have the audiophile 2496. Inside your comp, from the DVD player to the soundcard should be a digital connection, if not then you need to get a corresponding cable in order to do so (maybe someone else can help.. i can only visualize it, i dont know how to explain it better or the terminology involved..)..
  3. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    1) If the internal sound you've mentioned is "on board" on the mobo- go into bios and disable it (should be under integrated peripherals).
    2) The 2496 card DOES have digital output- you have to connect the little breakout cable that came with the card-- it connects to a serial-looking jack on the card, and has 2 midi jacks and two rca jacks: digitl input/digital output.
    -Vince
  4. Terry Wysocki
    Nov 21, 2001
    69
    Thanks for the help, but I'm confused as to how the DVD audio gets to the receiver. Am I not supposed to use the digital audio out jack on the DVD drive? Does the sound go thru the IDE cable to the sound card to the receiver via an RCA audio cable connecting the digital jacks?
  5. Cliff Watson
    Cliff Watson Agent
    Mar 6, 1999
    39
    ”Does the sound go thru the IDE cable to the sound card to the receiver via an RCA audio cable connecting the digital jacks?”
    Terry,
    That is exactly how the AP2496 works. It is not necessary to connect any other cables to the DVD drive.
  6. Vince Maskeeper
    Jan 18, 1999
    6,499
    Exactly!
    The audio and video go via the IDE connection.
    -Vince
  7. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    I believe that, if you want to use your HTPC as a music CD transport, you would still want to hook up the digital audio cable to your soundcard. I'm under the impression that music CD 'data' is sent out through either the analog or digital cable, depending on which you connect.
  8. Cliff Watson
    Cliff Watson Agent
    Mar 6, 1999
    39
    Johan,
    For the absolutely best audio quality the CD music should be extracted over the IDE buss in the same manner as DVD A/V. Almost all modern CD player use Digital Audio Extraction (DAE) to move the Redbook CD audio over the PCI buss to a soundcard for S/PDIF encoding or Digital to Analog Conversion. DAE also adds an extra layer of buffering to negate any jitter produced by the DVD/CD-ROM drive.
    DAE is the same method used to rip CDs to a hard drive or burn (copy) CDs.
  9. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Thanx Cliff.
