AUdio Source SW-15 owners
Discussion in 'Archived Threads 2001-2004' started by Sebastian, Apr 17, 2002.
  1. Sebastian
    Sebastian Second Unit
    Apr 14, 2002
    361
    I cannot find the accurate size of the enclosure. Seems that everyone online has differnet dimensions. Anyone know for sure the exact measurements?
    Oh yeah how does this woofer do on music?
    S
  2. BruZZi
    BruZZi Second Unit
    Nov 1, 1999
    327
    From Audio Source's web page:
    http://www.audiosource.net/00_sw15.html
    ________________________________________
    15-inch front firing driver
    Integrated 200-watt amplifier
    20 to 250 Hz frequency response
    Variable crossover 40 Hz to 180 Hz
    Auto-On circuitry
    Phase reverse switch
    20 x 16 x 20 in., 62 lbs.
  3. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    110
    20" depth
    16 and 3/4 wide
    20" high
  4. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
  5. Will Gatlin Jr
    Will Gatlin Jr Stunt Coordinator
    Mar 7, 2002
    201
    I think a lot depends on the spks that you use and the blending process that is involved. I use mine stricky for HT. If I did use it for music, I'd tune it as high (blending with mains) as possible, and use it as a slight roll-off. Good luck!!
  6. Sebastian
    Apr 14, 2002
    361
    Since it is a 15" I am worried that it will look too big in my house like some big ugly box. Does it look that much bigger than most 12" subs? Because I will at least buy 12" sub, but if there is not that much actual visual difference between the two, I will go with the SW15.
    Can this sub produce subtle bass? (baby)
  7. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    110
    The SW15 is big, It has a nice black wood grain type finish though. For the money, this is a very good sub. Produces powerful bass, and does fairly well in subtle bass. I did not like the sound of it with music. It won't compete with an SVS, but for the price it is excellent. I filled mine up with polyfill which took out much of the boominess that it comes with. Great sub for the money, but it isn't one that you can easily hide in a corner, it's big.
  8. rodney wiley
    rodney wiley Second Unit
    Nov 23, 2001
    307
    Im not sure of the dimensions but I have two. One was purchased from e-bay and is an older unit. The other was purchased from Amazon and is the latest. Th older unit is LARGER!
  9. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    Sebastian, Phil Iturralde wrote a great review of his new SVS 25-31 PCi comparing it to his AudioSource SW-15 here.
    Also, he has pictures of the two here.
    I'm sure you'll find everything you ever wanted to know about the AudioSource SW-15 at Phil's website, and then some! [​IMG]
    Vin
