Audio RCA Connections Amp to Receiver
Discussion in 'Archived Threads 2001-2004' started by Richie-C, Jun 25, 2002.
  1. Richie-C
    Richie-C Agent
    Jun 7, 2002
    27
    Looking for help on the type of connections to use for adding an amp to my HT setup. I have purchased a CineNova Grande 5 channel amp and am looking for recommendations on which interconnnects to use. I will be connecting to a 49tx. I have never used a separate amp before so this is a first time event.
    Do I need paired RCA inputs for all of the 5 channels?
    I need to run the connections around 13ft, so are there any suggestions out there for the cables to use without it costing an arm and leg?
    Rich
  2. Erik Farstad
    Erik Farstad Supporting Actor
    Jan 28, 2001
    560
    I went with Catcables and Doug the owner is a pleasure to work with! He'll customize ANYTHING for you and has the best bang for the buck that I've seen!
    www.catcables.com
    E
