Audio Problems with Bad Taste???
Discussion in 'Archived Threads 2001-2004' started by Len Berkoski, Dec 13, 2001.
  1. Len Berkoski
    Len Berkoski Stunt Coordinator
    Nov 14, 2001
    59
    Just wondering if anybody else has had audio problems with Bad Taste? I've noticed that the DD EX mix seems to drop out about every 10 seconds or so, but not always in the same place. (i.e. if I scan back and listen to the scene again, it will play fine but the "gap" will be elsewhere). This behavior is not present when using the DTS track.
    I'm using an Toshiba 2008SD player with an Onkyo 898 receiver with autosensing, and I've never had a problem like this on any other discs. If the dropouts were always in the same places, I would assume a defective disc (given Anchor Bay's quality problems). However, the "mobile" nature of the problem seems to indicate a compatibility problem with the player or receiver?
    Anybody?
  2. MaxY
    MaxY Guest
    Len,
    I had no such problems with my copy using a Sony 9000 ES. It might be a player type problem and I suggest trying it usiing a different DVD player if you can.
    Max
  3. Greg_Y
    Greg_Y Screenwriter
    Mar 7, 1999
    1,466
    No problems on a Pioneer 434 / Denon AVR-2700 combination.
  4. Len Berkoski
    Nov 14, 2001
    59
