Audio problem, please help
Discussion in 'Archived Threads 2001-2004' started by Paul Cole, Dec 5, 2001.
  1. Paul Cole
    Paul Cole Agent
    Aug 25, 2001
    31
    While watching tv programs, I'm noticing that the audio is cutting out on loud scenes and scenes with lots of quick cuts(like commercials). Sports too...when they show a swooshing graphic the audio cuts out for a split second.
    Maybe I have a bad cable box?
    Is my tv (sony hs10) messed up?
    It seems to happen more often at lower volume settings. I have tried different volume settings and combos between the cable box and tv but it is still happening.
    Any ideas?
  2. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Paul: You say that you've tried different combos between the cable box and the TV?
    If you've tried different cables/wires and the problem remains, then it still could be the box or the TV. Do you have a 2nd TV that you can try (or borrow one from a friend or relative?) If the problem remains, then you'll know it the cable box. If it goes away, then your TV is the source...
