Audio Ideas Imagers??
Discussion in 'Speakers' started by RyanJE, Mar 19, 2005.
  1. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
  2. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Come on anyone??
  3. Bob Cal
    Bob Cal Stunt Coordinator
    Dec 30, 2001
    58
    Ok. I will have to admit that I purchased a pair. Can't honestly say I noticed any difference. Someone else might have a different opinion.
  4. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    What kind of speakers did you use them on?
  5. Bob Cal
    Dec 30, 2001
    58
    Sorry, should have stated that.
    I used them on Paradigm Studio 60 V.2 Like I said I did not see any change, but then again someone else might. For the cost give them a shot.
    I should really try and do some comparison on them and see if there is a change. I guess I must be the only one to purchase them. [​IMG]
  6. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Do those have any kind of anti diffraction ring already? That might be why, no?
  7. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Depends on your speakers. One shape will not work for every tweeter. The relationship of the position of the drivers is important too.
    That thing has a vertical ridge on the inside, and would actually seem like it would cause problems, rather than solve them, for how tall they are.
    You should be able to do the same thing for next to nothing:
    http://www.soundandvisionmag.com/ide...?topicID=31143
  8. Bob Cal
    Dec 30, 2001
    58
    No this was a first time using this type of tweak.
  9. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    John I had a feeling you'd chime in on this eventually. I cant view the pics in that thread right now because im at work so ill check again later. Have you tried anything like this??
  10. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I've seen it done before on M&Ks and one or two other speakers though.
    My main HT speakers use the same tweeter, all of which have a little ridge for edge diffraction and the ones in my bedroom have an aluminum waveguide, and I am very happy with the way they both sound, so I haven't tried it out.
  11. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    How can I tell if my speakers have wave guides or anti diffraction set ups? What should I look for?
  12. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    If it's flat, there's no waveguide or diffraction ring. You can see here:
    [​IMG]
    the waveguide that is built into the front panel of my 902s
    You can see the "hump" on the GR T2 (aka "eyeball") tweeters used in all my GR Research speakers:
    [​IMG]
    In both cases, the tweeters are completely flush with the front face of the baffle (in the 902s case it IS the front baffle) and the guides should help minimize edge diffraction and aid dispersion.
    For what it's going to cost to try it out, even if your tweeters have waveguides, it's worth it to give it a try.
    This guy is an example of a tweeter that is basically flat
  13. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    I think I could consider mine flat as well then. How do you post a pic? I wanted to post a pic of my tweets.
    I may give this a whirl for how cheap it is.
  14. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    if the pic is on a public site, you can use the IMG or http:// buttons above the reply box.
  15. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    There not, I have them on my comp.. I also couldn't post my freq curve on another post.
  16. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Set up a yahoo account and you will have a free photo album that you can upload pics to.
  17. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Price of neoprene went up, huh?
  18. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    They obviously aren't using off shore labor to pump those things out [​IMG]
  19. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Thanks John I have a Yahoo account so Ill give that a go. I really do learn something new everyday.
