Audio - Digital Coax to Optical (tos-link) convertor (1 Viewer)
Derek_R
My new digital cable box only supports Digital Audio Coaxial out and I have run out of coax ins on my Denon 1802 however I have some Optical ins left.
I was wondering if anyone knew of something cheap that would convert the Coax to Optical.
-Derek
Eric_Lakes
Derek_R,
I wouldnt use any converters. Why dont you use the Optical cable for your DVD player and use the CoAxial for your Digital Cable Box instead.
FYI: I think Partsexpress.com has some sort of converter.
Chu Gai
David Susilo
Rat Shack also sells these things. Also does Midiman (the company that manufactures studio gears) for approximately US$ 40
why wouldn't anybody use converters? Major recording studios use them. Moreso, I used to use them for my studio as well as my HT, no change in sound quality.
Bob_L
Bob Lindstrom
No reason not to use convertors, I suppose; but in Derek's case I think putting a convertor in the chain would be more likely to make a bigger difference in the sound than using an optical instead of a coaxial connector for a single device.
I've gone back and forth comparing the two and, although I can hear a difference, it ain't that decisive a difference, IMO.
Derek_R
Thanks for all your help.
I ended up purchasing the Digital Coax To Optical converter at Parts Express.
I have had it for about a few weeks and can honestly say I've had no problems with it. I sense no lack of sound quality, no buzz, hum or external noise what so ever.
I recommend it to anyone looking for such a solution.
Again, thanks for all your help.
-d
S205449
