JayKellen
- May 22, 2003
I just bought a Toshiba Progressive Scan DVD Player, and had a quick question regarding what audio setting I should have the player on. I want it to utilize both Dolby Digital and DTS, and my options to choose from are Dolby Digital/PCM, Stream/PCM and a third that is just PCM. I have it set on the stream/pcm, for the manual mentioned that i should "select this if you connected the players digital out jack to an amp or equipment with a DTS decoder, Dolby Digital decoder OR MPEG decoder." I know this may be a silly question and I may have answered it myself already, but i just wanted to make sure I have it set up properly. The Dolby Digital/PCM is strictly for dolby digital sound and not dts correct?? Thanks for advice.
