Attractive electrical conduit??
Discussion in 'Home Theater Projects' started by Sean_P_O'Brien, Dec 17, 2003.
  1. Sean_P_O'Brien
    Nov 18, 2003
    39
    I am facing the strong possibility that I'll need to position my A/V stand and components approx. 8' from my widescreen rear projection television. I can run dedicated power and cable outlets to the stand, but would like to find something that will encase the audio/visual cables that need to connect back to the television. I am assuming I'll run them along the baseboard, then bend 90 degrees at the appropriate location behind the television.
    Do they make any type of electrical conduit for residential applications that is meant to look a little more attractive than standard commercial grade conduit?
  2. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    you could always run your cables through some Techflex, I think thats what I would do. If you do a search in the forums for it, you'll undoubtedly find some good places to purchase online.
  3. KenA
    KenA Stunt Coordinator
    Mar 28, 2000
    109
    Massapequa, NY
    Ken Appell
    Asthetics are very subjective, but Home Depot carries some platic conduit that snaps together. It has 90 degree elbows. You can always paint it the color of the background.
  4. Sean_P_O'Brien
    Nov 18, 2003
    39
    Ken and Owen,
    Thanks for the assistance at both locations.
