Attention: SonoTube Sub Builders
Discussion in 'Archived Threads 2001-2004' started by Dan Pawlowski, Dec 24, 2002.
  1. Dan Pawlowski
    Dan Pawlowski Stunt Coordinator
    Aug 12, 2002
    100
    I need advise.
    I am building a sonotube sub and it just occurred to be that most if not all glue will not stick to the wax covering found inside the walls of a sonotube.
    So:
    What type of adhesive did you use to fixate the MDF endcaps to sides of the sonotube??
    Dan
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The endcaps in a tube sub represent a pretty static load. If they are a good tight fit and sealed with a good caulk then no problems.
    In the several tube subs I've built I used Alex siliconized acrylic caulk. It works quite well
  3. Dan Pawlowski
    Aug 12, 2002
    100
    Thomas, Thanks for the reply
    Dan
  4. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    I used 1.5" thick mdf plugs with another 3/4" top cap. I then clamped all of them together and drilled three holes at the edge so I could clamp them down with threaded rod. I cut the plugs about 1/16" bigger(or even less) so the plugs would be pressure fitted.
    I then used bolts and washers at the top and bottom. The washers had a metal top and a rubber bottom that were slightly bowed so when tighten down they produced a seal. I also affixed the base plate with the threaded rod and some 4" plastic spacers.
    I went to a local carpet shop and bought some cheap foam for 6 bucks and lined the interior and exterior with foam using spray adhesive. I sealed all inside edges with sealant. got a black sock, painted my endcaps with some textured paint and sawed off the threaded rod flush to the bolt. I have a BP1503 in it and have not had a problem.
  5. Sebastian
    Sebastian Second Unit
    Apr 14, 2002
    361
    Just use some 60 grit sand paper on it and any adhesive will work.
    I used some stuff made by loctite at Target and it stuck with no issues at all.
