MattCPT
- Jun 13, 2002
Chu Gai,
I feel that I had to update you on how my quest to control my "bright" room was going. This was the least that I could do considering the very insightful reply you gave to my problem. Just to remind you, I currently have a Dolby pro-logic Yamaha receiver with Definitive Technology BP-30 Bipolar speakers (both know to be "bright". I loved my system when I had carpeting, but I recently tiled my house. I was trying to find out what interconnects or speaker cables I should buy to help my problem, and you suggested to give up on the cables and focus on my room. I had already added a thick wool carpet (helped a lot) and curtains (no noticeable effect).
I checked every site you suggested before going with any of them. I must say that I didn't bother with the software programs because they seemed like a lot of work and/or money. I was aware that acoustic panels existed but I always thought that they where gray/black convoluted foam, and that my wife wouldn't tolerate them. After looking at the sites you gave me I found that some of the products where colored or even covered in colored cloth. This doesn't excite my wife but they do look much better than anticipated, and leave me with the option of putting them in the closet when not listening to my system (you know, like when I'm sleeping or working ). I decided to purchase the Echo Busters 4 foot x 18 inches. These panels weren't cheap! They go for $280 without the base, but I figured that if they worked then it would be well worth the money. When I called the company the owner suggested 5 panels but I told him that my wife would never understand the "look" and I wasn't about to pay the price.
He told me that even 2 panels, one behind each speaker should help a lot. I was very skeptical but I knew that I could return them if not satisfied.
I received the panels just today. My first impression was that they looked professional. I turned up the volume on my Yamaha and played my Cranberries cd because the lead singers voice will go right through you. I did this without the Echo Busters the first time and as always I found the sound to be very bright and annoying. I then put the panels behind my speakers and played the song again. It was this moment that I knew I would be writing to you. The sound that came out was DRAMATICALLY better than what I had just heard. I was so surprised that I did this comparison with 4 more of the Cd's that I found to be overly bright and the difference was noticeable on all of them. WOW is what I kept thinking and saying. I even made my wife sit down with blind fold (myself too) to see if she heard a difference, and she was even impressed (not as much as me, but impressed). I think she liked the way they looked better with the blindfold , but that doesn't matter because I can store them if necessary. The difference in sound was even immediately noticeable when I would take the panel away from the speaker while a song was still playing.
I don't think that everyone will have these results, but in my system the change is wonderful. Keep in mind that my speakers are Bipolar, so that means that I have two cones and a titanium tweeter on the front and BACK of each speaker, causing added echoes. I don't find the music to be even a slight bit dull, in-fact the sound is still a little bright, but not even close to the annoying sound that I was getting. I found myself smiling for the first time while listening to music since I tiled my house. My urge to spend lots of money on cables has diminished significantly (not completely )
Sorry for going on and on, but what I'm trying to say is THANK YOU, THANK YOU , THANK YOU Chu Gai. I have learned a lot from the reply you gave me as well as replies that you have given others. I don't regret the money that I spent on the acoustic panels for even a second. I'm also a lot more excited about adding a DVD/SACD player and Dolby Digital receiver to my system.
Thanks again.
Matt
Thanks again.
Matt
