Attaching wires to binding posts (1 Viewer)
nolo
Grip
jeff
How are you supposed to attach speaker wires to binding posts. Are you supposed to come in through the side hole and tighten it down? I just came through the center hole and out one of the side holes and tightened it down. Is this acceptable?
gene c
Bay area, Ca
Gene
I think most people just go from the side but I doubt it really makes any difference. Going in through the center should work just as well.
JohnRice
Bounded In a Nutshell
A Mile High
Ideally, you want maximum metal to metal contact and do it by passing bare wire through the post and tightening it down.
HobbitGolf
