Attaching banana plugs
Discussion in 'Archived Threads 2001-2004' started by Yuli, Jul 28, 2002.
  1. Yuli
    Yuli Agent
    Jun 12, 2002
    38
    This may sound like a stupid question , but i need some help attaching speaker cable to banana plugs i bought. I got the gold plated RadioShack bananas (the ones that come as two pairs in one little box, around $9.99 CDN).
    I am using 12g speaker cable but the the banana passage is sligthly larger than the diameter of the cable. So how do i make a secure connection, without soldering?
    Thanks in advance...:b
  2. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    If you have the compression type bananas just screw the back part off the plug end, slip your wire in enough to stick out the compression end, fold over the wires and then screw the plug end back on. This should make them a pretty tight connection.
