ATI Amps?
Discussion in 'Archived Threads 2001-2004' started by Earl J, Sep 6, 2001.
  1. Earl J
    Earl J Stunt Coordinator
    Aug 23, 2001
    101
    anybody have any experience with the 1504 or 1505 models?
  2. Sankar
    Sankar Second Unit
    Aug 1, 1999
    315
    Yes .. I have the AT1505 mated to a Denon 3801. Great piece of work.
  3. TomH
    TomH Second Unit
    Jun 13, 2001
    267
    How does your 3801/ATI combo compare to the 5800?
    Tom
  4. Elbert Lee
    Elbert Lee Supporting Actor
    May 24, 2000
    501
    I've been using the 1505 for several years before upgrading to the 2505 (night and day difference due to power). Again, power is definitely great to have. I'm currently using the 5800 as a preamp for my 2505 and it's definitely an improvement over the 5800 by itself.
    I suspect that you'll have better results in certain areas by going with the 3801/1505 combo and a 5800 by itself. I think the 5800 will yeild a slightly more detailed sound, but the raw power of the 1505 will give you more focus in the bass and a brighter sound overall. But, it also depends on your speakers. If I were you, Invest in the 1505 first. You can always upgrade your preamp down the line. The 5800 or 5802 with 1505 down the line will still be better than a receiver by itself..
    Elbert
  5. Due N
    Due N Extra
    Aug 30, 2000
    20
    I owned the AT1505 briefly. I originally bought it for HT. I agree with Anthony. It's adequate for HT duty, not spectacular. It's nothing special for music. I have sold it since.
  6. Randy G
    Randy G Second Unit
    May 18, 2000
    460
    You might want to check out Sherbourn amps. They sound great, have tremendous power reserves, use a monoblock design, and I can get them for 25% off list. If you're interested, email me at theranman@webtv.net
  7. Bhagi Katbamna
    Bhagi Katbamna Supporting Actor
    Jun 1, 2000
    870
    I would agree with getting an amplifier for the mains and using the amps in your receiver for the surrounds. I would recommend an Anthem(which can be turned on by signal or voltage trigger)MCA-3. This would allow you to power the front 3 channels(so that they match) rather than the main L/R. You should be able to get the MCA-3 for about $600-$700.
