ATI 9800pro to a KV34HS510 via DVI
Discussion in 'Computers' started by Stephen-R, Sep 12, 2004.
  1. Stephen-R
    Stephen-R Agent
    Aug 28, 2004
    48
    Has anyone tried hooking up a 9800pro to a Sony KV34HS510 wide-screen tv by way of the DVI cable? I figured the TV is a glorified monitor when I purchased it. However, after reading the manual it states the TV is not for computer viewing. Hmmmmm.....just curious if anyone has tried to hook it up. I guess I could go downstairs and drag my puter upstairs and try it...
    Thanks for any replies....
  2. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    I dont see why it wouldnt work if its an actual crt, but since you mentioned that the manual stated its not for pc use id just be careful. the 9800 pro has a DVI-I connector so make sure the tv has the same.
