Athena AS-B1 or AS-R1
Discussion in 'Speakers & Subwoofers' started by RyanCai, Apr 25, 2004.
  1. RyanCai
    RyanCai Extra
    Mar 7, 2004
    24
    This is my setup right now.
    Fronts - As-F2
    Center - As-C1
    Rears - As-r1
    I want to do 6.1 or 7.1, which one should i get the B1s or R1s or anything else that you would recommend with my setup.
    Thanks in advance
  2. Scott*B
    Scott*B Stunt Coordinator
    Dec 16, 2003
    131
    If you need to wall hang them then R1's. If you're putting them on stands then the B1's.
  3. RyanCai
    RyanCai Extra
    Mar 7, 2004
    24
    So there is no difference besides hanging & putting them on stands?
  4. Scott*B
    Dec 16, 2003
    131
    Yeah they are different types of speakers altogether. However, the biggest reason to buy one over the other would be placement and not the technical differences.
