AS-F2 or Velodyne Sub?
Discussion in 'Speakers & Subwoofers' started by MikeGee, Mar 2, 2005.
  1. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    I have an option here..
    I just finished installing my Athena AS-B2's on my Pioneer 1014tx. The bass is very minimal even after i adjusted the EQ settings. (Unless anyone has any idea how to get a bit more bass outta these speakers on that amp)
    I would like to get more bass going but i am debating now between getting 2 tower speakers which would be Athena AS-F2 or the Velodyne DSP-12B. Either one is 600$ canadian.
    I have heard the Velodyne sub and i was quite impressed with how much power it had for the size of room it was in.
    I'm open to ideas.. if you have any suggestions on another sub to check out lemme know.
  2. Chuck_W
    Chuck_W Second Unit
    Dec 7, 2003
    397
    Mike...if you don't have a sub I would definitely choose a good sub over the speakers. I can't speak for the Velodyne as I've never heard it, but in my opinion a good sub with the B2s will get you better bass than the F2s without a sub.
    I have AS-F2s powered by the 1014 and find that by setting them to 'small' the sub (SVS PB12/2)gives much better bass than the F2s alone (for both movies and music).
  3. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    Not too many things that would give better bass then that PB12/2.
  4. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    Mikey you'd go with a JBL PB12 for a sub? I'm looking for somthing thats gonna have enough power to it but nothing out of this world. Any sub under 600$ canadian would be great.
  5. Raj_asaurus
    Raj_asaurus Stunt Coordinator
    Dec 17, 2003
    228
    he's talking SVSubwoofers.com PB12
  6. MikeyWeitz
    Feb 10, 2002
    939
    Yup, SVS
