As an interim tv, how is the SONY KV32HS42>
Discussion in 'Displays' started by Dick, Apr 14, 2005.
  1. Dick
    Dick Producer
    May 22, 1999
    6,013
    2,011
    Maine
    Rick
    Tweeter has one of these now-discontinued sets left and is selling it for $800. It is a 32" high def-ready set (4x3) and I have put a refundable deposit of 10% down on it. Wanted opinions from HTF before making my final decision. Does anyone own one of these? In combo with a Sony DVP-NS975 progressive scan player with HDMI output, would this be a good interim home theater display unit until I can afford a front projector/screen, etc.?
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    It's an excellent 4/3 HD ready set. If the size and aspect ratio don't bother you, you won't be going wrong by any means. For a few hundred more larger widescreen crt based rptvs in the neighborhood of 42-48" are readily available if you're not hung up on lcd or dlp, newer tech with worse pics and higher prices.
  3. Craig
    Craig Second Unit
    Oct 20, 1999
    467
    I've seen a Toshiba 46" RPTV on sale for $997 recently at H.H. Gregg, so there are 16x9 sets with larger screensizes available for only a little more if you want to spend that much.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    be warned.. I think this set comes in at around 200lbs or more!!! [​IMG]
  5. wayne-sun
    wayne-sun Agent
    Aug 1, 2002
    46
    Only 168lb, no problem (as long as you have a couple of strong guy's around on moving day)[​IMG]
