article from Sound & Vision about watts?
Discussion in 'AV Receivers' started by PeterN, Oct 15, 2003.
  1. PeterN
    PeterN Stunt Coordinator
    Feb 20, 2003
    68
    Can somebody post that link to the wattage measurement that Sound and Vision did?
  2. Jigesh Patel
    Jigesh Patel Stunt Coordinator
    Jun 16, 2003
    137
  3. PeterN
    Feb 20, 2003
    68
    yep, thats it! Thanks!
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    That's sweet. Be nice if they had the dBW numbers that S&V also promotes for comparing power between different components. I seem to remember that S&V says say that even though power levels can vary wildy between different receivers, that they think the dBW number (which does vary less between different receivers of similar power) is more important in a real room with real speakers. Something like that anyway. [​IMG]
  5. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    Yes I pay more attention to the dbW number than the true wattage measurements. That really equates to how loud you can play in terms of SPL. Its a better number IMHO.
  6. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
