Article for Jack Gilvey (cabinet thickness)
Discussion in 'Archived Threads 2001-2004' started by Jones_Rush, Mar 20, 2001.
  1. Jones_Rush
    Jones_Rush Stunt Coordinator
    Jan 19, 2001
    198
    Taken from: http://www.audioc.com/diy/Informatio...htm#construct:
    6) Cabinet Construction Techniques and Tips
    Minimize Resonance:
    Make it as close to solid concrete as possible! Once the basic design is worked out, there is nothing more important to the sound of your bass system than a very solid, non-resonant enclosure. Designers of commercial systems have to worry about the cost of materials and shipping weights. As a DIY, the cost of MDF is relatively cheap, and it makes sense to make your enclosure as solidly as possible. Designers of commercial systems make use of accelerometer / FFT testing etc. to accurately determine the most effective use of materials and internal bracing structures. As a DIY you can substitute pure "overkill".
    If you want a good, non-resonant enclosure without testing various bracing schemes etc., I’d recommend the following wall thickness:
    Enclosure Volume Recommended wall thickness, MDF:
    .5 to 1.0 cu.ft.------ ¾" thickness minimum
    1.0 to 2.0 cu.ft.----- 1" thickness minimum
    2.0 to 3.0 cu.ft.----- 1.5" thickness minimum
    3.0 to 5.0 cu.ft.----- 2" thickness minimum
    5.0 or larger--------- 2.5"-3" thickness
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Thanks. I don't know why you bothered to post this here, instead of answering your post over at PE...
  3. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,779
    493
    9,110
  4. Jeff Rosz
    Jeff Rosz Second Unit
    Sep 24, 2000
    335
  5. Jack Gilvey
    Mar 13, 1999
    4,948
  6. Jones_Rush
    Jan 19, 2001
    198
  7. Jack Gilvey
    Mar 13, 1999
    4,948
  8. Jones_Rush
    Jan 19, 2001
    198
  9. Jack Gilvey
    Mar 13, 1999
    4,948
    Ahh, so this "Jones" is not you? While this "Jones" is you?
    Funny. You posted this on 3/8. Seems eerily similar to that "PE Jones" post regarding 12" drivers. A quote from you:
  10. Jones_Rush
    Jan 19, 2001
    198
    The post at PE about board thickness was made by me,
    I also posted the documentation here for you.
    The Jones who made the post at PE regarding small room and "flat to 20hz" (Shiva vs Titanic 1200) is not me,
    you gave a link to it, so I looked and also posted another question (about the thickness issue).
