Can anyone list the 31 frequencies that this EQ can adjust?
Nov 28, 2001 #1 of 2 jeff peterson Supporting Actor Joined Nov 29, 1998 Messages 675 Can anyone list the 31 frequencies that this EQ can adjust?
Nov 28, 2001 #2 of 2 SVS-Ron Screenwriter Joined Jun 2, 2001 Messages 1,074 In the bass regions: 20Hz, 25, 31.5, 40, 50, 63, 80, 100, 125 So you have the big room mode areas covered and most of the low end. You also have adjustable ("High Pass" or subsonic filter that runs from 10Hz to 230Hz), level control and a bypass, +6dB or +12dB range settings. I LOVE this piece of gear! Not as powerful as a parametric eq, but VERY easy to use and more adjustment than most need. Ron
