ART 351 (EQ) increase signal level?
Discussion in 'AV Receivers' started by KyleGS, Jan 19, 2004.
  1. KyleGS
    KyleGS Second Unit
    Feb 12, 2002
    342
    Will the ART 351 increase the signal level to an amplifier? I'm using it for a DIY sub and running it directly to an outboard amp. Will it provide a "hotter" signal to the amp?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Theoretically yes. If you have more bands boosted than cut, then there will be a net signal gain. The level control would also boost the incoming signal, which will translate to a hotter signal at the output. However, any increase in gain from either of these situations will decrease the EQ’s headroom, so be careful.
    Wayne A. Pflughaupt
