Arrrgh! How can I get rid of ants??
Discussion in 'After Hours Lounge (Off Topic)' started by Alf S, Mar 12, 2004.
  1. Alf S
    Alf S Cinematographer
    Apr 23, 2000
    2,981
    509
    4,110
    Alfer
    Around here we call them piss ants cause they piss us off I guess...
    They are teeny tiny little ants (less than an 1/8" long maybe) that show up in our kitchen EVERY spring..then disappear in the summer, fall and winter.
    I've sprayed the exterior foundation area of the house where the kitchen and back door are...I've layed down numeroud ant traps (those little black plastic discs by Raid) and still can't get these things to go away!
    I can NEVER actually find a trail leading into the house nor a path that they are walking from within the house...they just randomly roam the kitchen.
    And yes we try to keep the kitchen spotless and avoid keeping food out on the counters etc.
    Does anyone know of a good methods to get rid of these critters?
    Note we have a 2-1/2 year old and 2 cats in the house so I don't really want to spray inside the house.
    Thanks!
    Alfer
  2. Bob Graz
    Bob Graz Supporting Actor
    Sep 26, 2002
    798
    Best thing I've ever found to get rid of them is called Terro. You can get it at Ace or Home Depot. You put it on pieces of cardboard. It actually attracts the ants and they carry it back to their nest and kills the nest off. It's very effective. It takes a week or so and they will be gone.
  3. Alf S
    Apr 23, 2000
    2,981
    509
    4,110
    Alfer
    Thanks Bob! I'll give it a try.
  4. Vickie_M
    Vickie_M Producer
    Dec 31, 2001
    3,208
    A tip to help try and find the nest: get some Instant grits and put them down on a paper towel or something. After a while check it, and you should see each ant carrying a grit. Follow the ants to see where they take it. I found a nest using that method a couple of years ago. The tip I read was to use grits to kill them (they'll eat it, it'll absorb the liquid in their bodies and they'll either go kaboom or dry up) but it worked for finding the nest too. It was fascinating watching the ants carrying them across the kitchen floor, go through a tiny hole at the bottom of the kitchen door, outside, then up the side of the building into a notch in a brick about 2 feet above the door. One ant, one grit, but it would be like a human carrying a boulder up the side of a mountain. Amazing.
    Use the quickest, most instant-type grits you can find. You could also mix in some sugar and, if there weren't kids and cats, boric acid.
    I can't remember where I read that tip. If it was here in HTF, thanks whoever! It worked for me.
  5. Jim Sit
    Jim Sit Extra
    Jul 26, 2003
    16
    I had ants jus like yours and also didn't like to spray inside. Here's what worked for me:
    Don't just spray the foundation, all that does is force those ants inside to stay inside.
    Start with traps, trying a few different brands and types to see which the ants have the best reaction to. Put them in all of the places you see ants, inside and out. As described above, the best traps are those where the poison is brought back to the nest and given to the queen. Watch the ants carry the poison out of the trap and take it to the nest.
    Observe them as much as you can. Once you see them carrying dead ant bodies, that's when you know the colony has been destroyed. Shortly after that is when you want to protect the perimeter of your house. Diazinon is a good choice for setting up a barrier.
    Using this method, I was able to control a serious ant problem without spraying in the house.
  6. Jim_F
    Jim_F Screenwriter
    May 15, 2000
    1,077
    N-ETHYL PERFLUOROOCTANE SULFONAMIDE
    is the best active ingredient I've tried. Raid used to make baits with it, maybe they still do, but they've changed some names in their product line. The ants go after it like it's a massive dinner party (product contains peanut butter) then disappear after a couple weeks. The best part is the virtually non-existent mammalian toxicity at the available concentrations. If a small dog ate the whole box, you'd only need concern yourself with the foreign body ingestion, not the active ingredient.
  7. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    Before we moved, we had those seasonal little critters............. GF used Murphy's Oil Soap on the window sill and other areas......... those buggers wouldn't go near the stuff!
  8. Jon.M
    Jon.M Stunt Coordinator
    Feb 13, 2004
    60
    If you want to use ant baits, I've found that the Combat ant baits work far better than the Raid ones. I had both in my kitchen a few years ago and the ants hit the Combat baits like it was a gourmet meal, while they didn't bother touching the Raid baits. Another good weapon is boric acid, which makes the ants dry out from the inside once ingested. I'd also second the recommendation for spraying the perimeter of the house with Diazinon twice a year (spring and fall.) An exterminator told me about that a few years ago and since I started spraying around the foundation, my ant problems have been markedly reduced.
  9. WarrenL
    WarrenL Stunt Coordinator
    Jan 25, 2004
    64
    Another vote for Terro!
    We had tons of ants inside and within a week they were gone. Our situation was very severe, so a couple of months down the road we had to do it again, even though we kept things super clean, but that was the last time we had an ant problem...this was last summer! [​IMG]
  10. Wade
    Wade Stunt Coordinator
    Jun 30, 1997
    147
    Hopefully you wont mind me jumping in on your ant thread with a different question regarding a different ant.
    What's the best way to get rid of fire ants from your yard? I was out measuring the yard in preparation for some landscape work when I happened upon two fire ant mounds. These guys are aggressive little pests. I was tapping the tape measure outside their mound and they started coming out in numbers and actually clamped onto the metal end of the tape. I really pissed them off when I started stamping their mound with my foot. They've since rebuilt. I don't want these guys anywhere near the house. I thought about pouring boiling water down their mounds but wasn't sure this would work.
    Any suggestions?
    Wade
  11. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    I always found that a good pied piper always works.
    Brent
    spelling good like? me not sure!
    I just thought about my statement and realized it would be for mice DUH!
    Nevermind, just ignore me!
  12. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Did they start swinging you around the yard after that? Ants are supposed to be very strong... Does anyone else think that would be a funny site? :b
  13. DarrenHo
    DarrenHo Stunt Coordinator
    Feb 20, 2004
    127
    for fireants, i'd call your local health dept. most communities have abatement programs. for the little black ants that get in the house, i found an exterminator the best way to get ride of them. they sprayed and the ants were gone the same day. never saw them again.
  14. Craig Robertson
    Craig Robertson Supporting Actor
    May 12, 1999
    982
    Wade,
    go to the cleaning aisle in the supermarket and get a box of boraxo. the low level of boric acid in it will kill the ants. make a circle around the mound and sprinkle it on top of the mound. the ants will pick it up and carry it into their nest and it will kill them.
  15. Bob Graz
    Sep 26, 2002
    798
    How to get of fire ants, I'm afraid fire ants win. You'll need to move to a state that doesn't have them. When I lived in Austin, the best stuff I found for fire ants was orthene. It has a terrible smell but if sprinkled on the mound would kill them in a couple of days. Unfortunately, it only takes care of that particular mound. Fire ants are probably the nastiest damn thing I've come across. I hate those little bastards. Thank goodness, although I hear they are in NC, I've haven't seen one in the 8 years I've been here.
  16. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    I got some Ortho powder from Home Depot for getting rid of fire ant mounds. It works pretty good. It stinks too, but it kills the fire ants. It's a very fine powder. When you open it the top is covered by a seal, just puncture the seal a few times and then you hold it over the mound and squeeze the bottle and put a fine dusting over the mound. Within hours I'd say the mound is all but dead.
