Arrgghh!!! What's wrong with my Mackie???
Discussion in 'Archived Threads 2001-2004' started by Dave George, Jun 13, 2002.
  1. Dave George
    Dave George Stunt Coordinator
    Sep 6, 1999
    71
    Well, I got my dual DIY tempest all hooked up, turned on my mackie m1400i, and heard....nothing. The power light comes on, but I get no signal lights for either chanel. All the switches should be in the proper position. I tried it straight from my marantz av-550 and through a paradigm x-30 xover. I've got rca's from the preamp to the mackie with 1/4" adapters on the end. I'm thinking maybe the output voltage of the home equipment isn't working with a pro amp, but I don't really know much about pro gear. Any suggestions?
  2. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    Dave,
    short of having a defective unit, all should be fine. I run my Mackie FR1400 with dual Tempests with great success. That amp can run at 2ohms stereo all day long from a regular outlet. You should phone Mackie, most of the 1400's are still under warranty, i think.
    Craig
  3. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Yes input/output impedace/voltage shouldn't be an issue,there is something else for sure.
  4. Ted Kim
    Ted Kim Stunt Coordinator
    Apr 11, 2002
    214
    try using the mackie to run your stereo speakers using the receiver as a preamp. If that doesn't work, its probably a problem with the Mackie.
