Bob McElfresh
- May 22, 1999
I bought a 40 G Maxtor hard drive and followed the instruction to swap out the old one.
The system boots up and then announces it has to check the WebTV site for an update. The modem dials and the "CONNECT" light on the front stays on for about 20 minutes. Then disconnects and announces "There was a problem" and gives me a "RETRY" button.
Thats it. I did this 7 times and it failed each time.
I found the service announcement about DishPlayers not liking to take an initial DL of software with a Dual LNB. But my error does not match the error described in the bulletin. It also does not respond to the Off-Option-611-On sequence designed to do a full-reset as described in the bulletin after hooking it up to a single LNB dish.
Any advice (other than putting the old hard drive back in?)
